Author: Subject: firebalde engine temp
met
posted on 8/10/05 at 07:30 AM Reply With Quote
can anyone tell me the normal operating temo range of my 98 blade engine in my st bec? its been a while since my r1 but i pretty much remeber that in the summer she used to run over the 100's? any ideas of normal temps in the bec, and extreme capable temps etc? mine doesnt have a cooling fan either
thanks
posted on 8/10/05 at 07:36 AM Reply With Quote
Typically between 85-95 degrees C.
No cooling fan you're pushing your luck aren't you? Personally I'd put one on ASAP. The resulting degredation of oil at high temperatures (110+) would be catastrophic for the engine. However, as our's didn't trigger that often, typical slow, non-stop road driving should be ok. But I'd still putone on to be sure!
met
posted on 8/10/05 at 07:40 AM Reply With Quote
thanks, yes my normal usage is popping here n there or out for a blt and it doesnt see temps of more than the 80's even on a hot day in traffic, im toying with selling it as i need some money fairly quick (secretly hope that no one buys it though) is s-v-c the cheapest/stroke best place online?
thanks very much
Snuggs
posted on 8/10/05 at 08:06 AM Reply With Quote
Try here.
http://www.nfauto.co.uk/cooling_fans.htm
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Avoneer
posted on 8/10/05 at 10:43 AM Reply With Quote
If you're using a car rad, try lolocost - under £15 for a good one.
Pat...
shortie
posted on 8/10/05 at 05:59 PM Reply With Quote
mine runs around 86deg, no fan is an uneccessary risk really as they are cheap and could save your engine IMHO!!
Rich.
met
posted on 8/10/05 at 06:31 PM Reply With Quote
looks like ill be getting a fan then, i presume they come with some sort of fitting kit? if i order one of svc?
thanks
met
posted on 15/10/05 at 09:10 PM Reply With Quote
pacet kit in the post and will be fitted in the next couple of days
met
posted on 20/10/05 at 07:08 PM Reply With Quote
fans now fitted, what temp would you guys recommend that i clicj the fan on, its on a thermostat and youre supposed to let the engine temp get to around "highway" temp?? and then wind the dial thingy, whats the general consensus though? 70deg?
also the way ive wired it the fan is behind the rad, ie between the rad and engine and its pulling, ie sucking air from the rad in, is that right or should i re-wire so its blowing?
ta
ChrisGamlin
posted on 21/10/05 at 06:16 PM Reply With Quote
The fan doesnt want to be kicking in until nearly 100c, on the bike its actually slightly over 100c I seem to recall.
Sucking is good
met
posted on 21/10/05 at 06:33 PM Reply With Quote
thanks, called pacet today and they told me sucking is the way to go too.
ta
