Author: Subject: Weber 40's or 45's
donut
posted on 12/10/05 at 04:21 PM Reply With Quote
Weber 40's or 45's
Right.... there are some cheap Webber 40's up for grabs which i'm tempted to purchase. Would these be ok for a 2 litre std pinto or would it really be worth while waiting for 45's to pop up. Is there any power increase with 40's or 45's on a std engine?
ta
ady8077
posted on 12/10/05 at 04:23 PM Reply With Quote
Hi
I had 40's on a standard ex injection pinto, made 130 bhp, no probs
Adrian
donut
posted on 12/10/05 at 04:27 PM Reply With Quote
Is it the 40's that made the bhp increase or the fact it was ex injection?
Danozeman
posted on 12/10/05 at 04:28 PM Reply With Quote
Id go for the 40's. Theyl be more than enough. The end of the day if you find they arnt right then you can always sell and get 45's.
Dan
Tiger Super Six
posted on 12/10/05 at 04:31 PM Reply With Quote
I had a standard 2.0ltr pinto on 45's and it was over carbed. Coughed and spluttered and this appears to be the case on most engines that I know.
40's should be more than enough as already said.
Mark
Mark
Tiger Avon
posted on 12/10/05 at 04:38 PM Reply With Quote
Mark
All depends what venturis you had in it.
flak monkey
posted on 12/10/05 at 04:50 PM Reply With Quote
IIRC even for a well tuned (and I'm not talking silly tuning here) 2litre pinto, the chokes to fit are 38mm. Which will just fit into 40's. So you should have no trouble with 40's unless you want stupid power.
I just got myself a 38DGAS Carb (all of £40 with a K&N and inlet manifold). Its another option for a good power boost from the standard carb (cheap too)
Sera
http://www.motosera.com
Surrey Dave
posted on 12/10/05 at 04:55 PM Reply With Quote
Answer
The answer is here:
http://hometown.aol.com/dvandrews/webers.htm
Are the carbs a pair? are they jetted near your requirements?are they in good condition, cost for spares can mount up really quickly when you've got to buy 4 of everything.
And i managed to not mention bike carbs.........oh poo!!!
gazza285
posted on 12/10/05 at 04:59 PM Reply With Quote
I think you will find the biggest venturis for a DCO40 are 36mm and these do not really provide a good venturi effect. 34mm should really be seen as the biggest venturi for a DCO40 carb.
Have a look at what Dave Andrews has to say.Font of knowledge
gazza285
posted on 12/10/05 at 05:00 PM Reply With Quote
Quicker than me.
mookaloid
posted on 12/10/05 at 05:02 PM Reply With Quote
I have found Dave Andrews take on this to be fairly reasonable
I think 40's are ok for a standard engine (just) but if you are ever going to go for more power you would be better off with 45's.
As Mr Britishtrident says the venturi (choke) size is actually the critical thing
I bought a set of cheap 40's and had to sell tham again as they would have cost a fortune in new chokes and jets etc - it was cheaper to get some 45's in the long run.
However having said all that, If I was doing it now, I would forget Webers and have bike carbs or throttle bodies + megasquirt instead anyway
Mark
mookaloid
posted on 12/10/05 at 05:03 PM Reply With Quote
Damn....must type quicker
donut
posted on 12/10/05 at 05:06 PM Reply With Quote
Most helpful thank you.
Dave - you let yourself down metioning bike carbs...tsk tsk. ( i won't tell him i have been looking for gsxr carbs on Ebay!!.......oops!)
