dave1888
| posted on 12/10/05 at 09:21 PM |
bike carbs and megajolt
I have a set of R1 carbs which have a TPS fitted to them would i be able to use this with my megajolt system. Also does anyone know if the main jets
in the carbs have to be changed/drilled to run on a 1600 zetec. If they have to be drilled does anyone know the diameter
Thanks.
Kissy
| posted on 13/10/05 at 06:15 AM |
You need to get it running then get to a rolling road - ideally with several sets of jets and some needles - a road that knows bike engines as well, a
lot of them do not!
Surrey Dave
| posted on 13/10/05 at 08:50 AM |
Bogg Bros
Bogg Bros are very helpful ,and setup a lot of these so can probably guess quite well, but they would recommend perfecting it on a rolling road, I
dont know the size of R1 main jets but my Suzuki 38mm carbs where 115 , they are now drilled to 165 I think, wouldnt run well up the top end until
they where over 140. I have a lamda readout in my car so I've got an idea whatss going on( made with 10 led's and a few components)
[Edited on 13/10/05 by Surrey Dave]
