BKLOCO
| posted on 14/10/05 at 03:09 PM |
Gearbox oil.
Please forgive me if this has been discussed before but I am interested to know what oil people are running in their type 9's.
Are most running the standard 80/90 or do you now run synthetic oil?
If you look in the Halfrauds guide they say mineral for carburated Sierra's and synth for injected.
Interested to know what everybody in locost/seven land is doing.
| posted on 14/10/05 at 05:39 PM |
Once put standard 80/90 oil in a sierra , big mistake. Made gear change and selection hard work had to syphon oil out of filler hole and refill with
the correct oil. Can't remember what I put in my box but may be able to check tommorrow as I haven;t any lights in garage at the moment and my
torch batteries are dead.
| posted on 14/10/05 at 08:07 PM |
SAE 80 EP
That's what they come with from Ford. Mine has it in and no problems with it. What difference does carbs or injection make to the gearbox?.
You've lost me on that one.
BKLOCO
| posted on 14/10/05 at 09:08 PM |
I've no idea what difference carbs or injection make, it's just what Halfrauds say in their book!!!!
paulf
| posted on 15/10/05 at 06:24 PM |
The later MT75 box had a particular oil for it and was probably the box fitted to injection cars.It is a thin oil similiar in appearance to
autotransmission fluid, I know bcause i bought some by mistake and found out as i was about to pour it in. I used 80/90 for my type 9 box with no
problems.
Paul.
| posted on 15/10/05 at 06:59 PM |
Used a semisynthetic oil in mine , as already stated 80/90 can cause problems and is a pig to get out . Haynes say use semisynthetic if gear selection
problems occur.
