givemethebighammer
| posted on 23/10/05 at 08:05 PM |
Expansion tank question
Can you get an expansion tank with just one inlet ? If so from which vehicle. I run a water rail on my zetec that has an overflow pipe that just dumps
the water as the engine heats up and the system finds it's own level (raceline say this is how it should be). However after a good thrash (such
as a track day) I have to top the coolant up with up to a litre of water. My thinking is that I could replace the cap on the water rail with a non
pressure release version, run the overflow pipe to an expansion tank that has a pressure release cap fitted to it (hence the single inlet tank
question) and no more lost coolant.
| posted on 23/10/05 at 08:07 PM |
cant help you there, but on my car, i did a trackday with no header or expansion tank, and no fan working, and it worked well for many laps.
Admittedly it wasnt exactly a hot day!
givemethebighammer
| posted on 23/10/05 at 08:10 PM |
thanks Joel, it works fine even on a hot day, it's just a pain to have to keep topping the system up. Bit worried about losing the antifreeze as
well.
mark chandler
| posted on 23/10/05 at 09:41 PM |
classic range rover, SD1 have small copper tanks with a 1/4" pipe to feed them and standard rad cap.
NS Dev
| posted on 23/10/05 at 10:33 PM |
they are the special builders friend are those Rover tanks!
You can make up extra brass hose barbs and drill the tank and solder them in wherever you like, really cheap solution that looks tidy too!
Humbug
| posted on 24/10/05 at 07:22 AM |
Don't know if you still need an expansion tank but I have 2 spare:
1 pressurised from a Metro (but it has 3 connectors!)
1 non-pressurised with only 1 connector
Here's my original ad with pics:
http://www.locostbuilders.co.uk/viewthread.php?tid=30707
Ketchup
| posted on 24/10/05 at 12:46 PM |
most jap motors have a small top-up tank for the cooling system.. one pipe to the top of the rad.. a one-way valve in line or normally built into the
cap on the reservoir so the cooling system can still pressurise.. and will draw coolant into the system if it needs it.
any nissan micra has one with a valve built into the cap, they hold about half a litre.. prob cost u a fiver from any scrapyard.
dunno if that helps
clbarclay
| posted on 24/10/05 at 01:23 PM |
Be warned of diesel range rovers and SD1's their expansion tanks have 2 connections to the cooling system (bottom hose and top of rad/block).
Still made from tin so can be soldered/brazed if needs be (block up top hole by brazing).
[Edited on 24/10/05 by clbarclay]
givemethebighammer
| posted on 24/10/05 at 09:36 PM |
thanks people found this today
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?s=a0406b58fd2f3254b983e2a434b16841;act=ST;f=3;t=6277;st=0
seems that the Jap thing is the way to go
K11 Micra, small tank with single inlet at the bottom.
However if I find a range rover I might be tempted !
thanks again
NS Dev
| posted on 25/10/05 at 12:05 AM |
Another common tank with 1 small OD outlet (just read the westy forum bit and it seems you're not the only one with the problem!) is the renault
one fitted to most 80's renaults, fairly neat too, round bottle with a single outlet in the base, may even have one laying about, I'll
have a look tomorrow evening for you as you're not far away to pick it up!
