dave1888
| posted on 26/10/05 at 05:34 PM |
leaking sump
I checked my zetec sump (alloy) today and discovered a pin sized hole near where the sump bolt has been welded in. I dont want to go to the bother of
getting it ground out and rewelded. So is there anything i can use to seal it like chemical metal or the likes and would it be safe to use on the
inside of the sump.
flak monkey
| posted on 26/10/05 at 05:36 PM |
Probably JB weld...seems to be used for everything else...
Sera
http://www.motosera.com
john_p_b
| posted on 26/10/05 at 09:13 PM |
leakfix! can't remember who it's made by but it's sold at halfrauds in a yellow tube with a seperate hardner with it.
had exactly the same problem with my sump 2 days before sva test, cleaned it up, spread some of said leak fix over the whole and it's been sound
ever since. also seems to be holding out on my fuel tank quite well too!
built a car, built a home, had a family. lost the family, lost the home, still got the car.
owelly
| posted on 26/10/05 at 10:28 PM |
Use a blunt centre punch to pein around/over the hole. That will seal it but squish some of the aforementioned sealers in to make sure!!
http://www.ppcmag.co.uk
| posted on 27/10/05 at 03:10 PM |
Dril a hole and tap it then screw in a set screw with a drop or two of Loctite "lock & seal" on it.
Rorty
| posted on 28/10/05 at 04:49 AM |
So you're the person who put those grub screws in the sump of that engine I bought!
Cheers, Rorty.
dave1888
| posted on 28/10/05 at 07:46 AM |
Problem fixed with some araldite steel fix stuff
