rich201283
| posted on 26/10/05 at 10:01 PM |
Dcoe carb setup
I have a x flow with a single dcoe carb on it, The guy i bought the car off said he has just put a repair kit on it, When i go round corners it
splutters, i goes preaty well in a straight line, also its no running has smoth as it should i dont think, Any ideas on setting this up again?
CGILL
| posted on 27/10/05 at 03:56 AM |
I would check the castings where the pin for the float pass through, it is common for these to be broken and the float level can be a bit off, if all
ok, just adjust the float level. If it is broken it can be repaired by using solvent proof epoxy to hold the pin in place.
| posted on 27/10/05 at 03:15 PM |
Check the floats are set at the correct height.
ghost_walker
| posted on 27/10/05 at 09:49 PM |
check the floats ain't holed by placing them in water
there is only three speeds. fast, very fast and oh shit!!!
| posted on 27/10/05 at 11:34 PM |
Don't go round corners.
Any baffles in the tank?
