Author: Subject: ST170 Sump
Dave Bailey
posted on 14/11/05 at 07:00 PM Reply With Quote
ST170 Sump
Does anyone actually understand the difference between the zetec engines. I have an st170 engine and I need to know if the dry sump system that pace sell for the zetec will fit an st170. I have a shallow steel sump then an alloy baffled spacer that bolts to the cast iron block. The problem also seems to be that this alloy section seems to have mounting holes for the gearbox and yet the pace dry sump doesn't seem to have any. I am fitting a type 9. OOOOOO errrr I have a headache!
stevebubs
posted on 14/11/05 at 07:15 PM Reply With Quote
You won't use the sump holes to mount the Type 9 on any zetec.
As far as I understand it, all zetecs use fundamentally the same block (silver/blacktop differences aside) so shouldn't be an issue for you.
I'd expect the Focus RS and ST170 systems to be the same as for the Phase 3 blacktop. However, Pace should be able to advise.
Stephen
Stephen
Dave Bailey
posted on 14/11/05 at 07:39 PM Reply With Quote
I spoke to Pace today and they were not sure!
Thanks for the info and advice
Project7
posted on 14/11/05 at 07:40 PM Reply With Quote
What you described there sounds like what i have on my standard zetec.
Steves' right the ST170 is a Zetec block with a VVT Head.
I'd still check with pace to make sure though
Project7
posted on 14/11/05 at 07:43 PM Reply With Quote
you just hit the post button before me
here is a picture of the normal (late type)zetec sump (not sure it'll help though)
Image deleted by owner
[Edited on 14/11/05 by Project7]
stevebubs
posted on 14/11/05 at 09:00 PM Reply With Quote
To mate to a Type 9, you'll need to cut away most of that webbing as that is where the starter will want to sit...
stevebubs
posted on 14/11/05 at 09:04 PM Reply With Quote
I've a standard Titan Dry Sump pan knocking around in the garage if you're localish and want to measure it up...
Stephen
PS Done about 1k road miles now with a Phase 3 zetec with self-baffled and shortened wet sump
[Edited on 14/11/05 by stevebubs]
Dave Bailey
posted on 14/11/05 at 10:19 PM Reply With Quote
Steve,
Where do you live?
Can you confirm that your phase 3 has an ally section down from the crank then a shallow steel sump. This is the layout of the ST170 motor. I took off the steel part and there seems to be baffles in the ally bit which may mean I can use the engine as it is although part of the reason for the dry sump was to improve ground clearance. Ref your titan pan.... do you want to sell it?
thanks
Dave B
stevebubs
posted on 15/11/05 at 12:16 AM Reply With Quote
Reading (Berks)
Yep - has ali top and steel bottom - that's why I modded it myself (don't have tig for ali)
wrt Sump - no, don't want to sell it but if you call round the FF places advertising on the forums you can sometimes pick them up.
That's what I did and the pan cost me about £50. Got a pump somewhere I need to rebuild, too.
Those are upgrades for (if) when I go the turbo route, though
[Edited on 15/11/05 by stevebubs]
stevebubs
posted on 15/11/05 at 12:25 AM Reply With Quote
Sorry to repeat from the other thread, but look here for more confirmation as to what you have
Dave Bailey
posted on 15/11/05 at 12:28 PM Reply With Quote
The link was great! I now know I have a phase 3 sump. Is it necessary to further baffle the sump on a phase 3. Maybe the dry sump route at this time is a bit of an overkill.
thanks for all the help.
Dave Bailey
Tiger Super Six
posted on 15/11/05 at 02:44 PM Reply With Quote
I have a black top zetec and went for the raceline wet sump (which is a good bit of kit and is proven in races).
The main difference for the sump between the series 1/2 and series 3's is that the windage tray forms part of the sump.
With a series 1/2 you can change the sump and the windage tray stays attached to the bottom of the engine. With a series 3 when you take the sump off the windage tray is also removed.
Therefore if you replace this with a dry sump or alternative you will need to take this into account. With the Raceline sump they provide a windage tray to fit into the new sump (which is well baffled). I assume that if you went to pace they would be able to provide the same.
HTH
Mark.
[Edited on 15/11/05 by Tiger Super Six]
Mark
Tiger Avon
