Author: Subject: Kent RL21 cam any good for an injection setup?
Mark Allanson
posted on 17/11/05 at 10:58 PM Reply With Quote
Basically as the subject, will it be any good?, is a second hand cam c/w followers a good thing or a definite nono?
Answers on a postcard....
Mark
posted on 17/11/05 at 11:10 PM Reply With Quote
S/H cam and followers is fine provided it not obviously worn and the followers have been kept in the correct order, i.e. each cam lobe should be matched to it's original follower.
However, the RL21 is possibly a little too "hairy" to be used with the original flap type air flow meter which get quite upset with the strong pulses that are produced in the inlet manifold from long duration/high lift cams.
Mark Allanson
posted on 17/11/05 at 11:14 PM Reply With Quote
Bugger, it is so cheap as well!
best keep my eye open for a FR32 instead
CairB
posted on 18/11/05 at 12:46 PM Reply With Quote
Mark,
I fitted an FR34 to the pinto with the standard ECU. Felt a lot quicker.
On the other hand, how about joining the bandwaggon and going Megasquirt and doing away with the restrictive MAF?
Colin
Mark Allanson
posted on 18/11/05 at 09:30 PM Reply With Quote
I just have a standard cam with wear reduced lobes, so even a std replacement will probably feel faster, just thought I would upgrade at the same time. I have already drilled out my spray rail. Megasquirt, sounds very complicated to me
DarrenW
posted on 24/11/05 at 12:47 PM Reply With Quote
Andrew down the road from me has a FR32 for you Mark. I think he has U2U'd you.
Mark Allanson
posted on 24/11/05 at 08:59 PM Reply With Quote
Unfortunately, he wants three times what the FL21 went for, I would have bought it to give it a try if a little cheaper, but at that price, it needs a little more weighing up
