Author: Subject: Exhaust joint question ...
RazMan
posted on 2/12/05 at 08:55 PM Reply With Quote
I have a question regarding the application of exhaust clamps?
I need to clamp a 50mm/ 55mm sliding joint in a V6 collector box. The tubes are just clean cut – should I cut slots in the outer tube to improve clamping force or just use some HT gasket compound to take up the slack?
Raz
