Author: Subject: Electrical switch from clutch????
Jasper
posted on 9/12/05 at 01:01 PM Reply With Quote
The part built car I've bought has an electrical switch from the clutch master cylinder - any ideas why this would be? Original engine would have been a Duratec
ChrisGamlin
posted on 9/12/05 at 01:13 PM Reply With Quote
Fluid level maybe, or a switch so the car only starts with the clutch down?
ReMan
posted on 9/12/05 at 01:40 PM Reply With Quote
Cruise control?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Danozeman
posted on 9/12/05 at 01:44 PM Reply With Quote
Standard ecu used?
Dan
stevebubs
posted on 9/12/05 at 03:25 PM Reply With Quote
Fluid Low level?
[Edited on 9/12/05 by stevebubs]
caber
posted on 9/12/05 at 05:45 PM Reply With Quote
Somebody used a brake master cylinder for the clutch?
Caber
Deckman001
posted on 9/12/05 at 07:03 PM Reply With Quote
Don't worry about it, I'll run it in series with the brake fluid level, that way you get a warning if either level goes down !!
Jason
[Edited on 9/12/05 by Deckman001]
ady8077
posted on 9/12/05 at 07:34 PM Reply With Quote
Hi Jasper
Is it a level switch or a pressure switch?
If pressure it may have been to connect to the ecu for full throttle gearchanges
Adrian
flak monkey
posted on 9/12/05 at 07:38 PM Reply With Quote
Clutch fluid level sensor
Sera
http://www.motosera.com
Chippy
posted on 9/12/05 at 11:31 PM Reply With Quote
More of a discription would be handy, but if it's got a float attached it has got to be a fluid level warning.
Jasper
posted on 11/12/05 at 02:51 PM Reply With Quote
Cheers for the reply chaps - just gonna ditch it completely......
