Author: Subject: black soot around tail pipe
jimmyc123
posted on 23/12/05 at 09:51 AM Reply With Quote
has anyone got any idea why my exhaust has black soot around the tail pipe ?
is the engine running too rich?
cheers
JIm
jos
posted on 23/12/05 at 10:12 AM Reply With Quote
Its usually a faily good sign that the mixture needs looking at.
I too have got lots of soot around the inside of the tail pipe from having too rich a mixture.
I'll clean it up and monitor it as the mixture settings have been looked into and hopefully sorted.
The tail pipe is a good indicator of how happy the engine is.
jimmyc123
posted on 23/12/05 at 11:12 AM Reply With Quote
thanks mate,
think you are right as i have just recently bought the car from scoobyis2cool.
he said he was having trouble getting the engine to idle properly. Which it is still doing so ill need to get it checked out as im not too hot on carbs.
( it drinks like a gooden as well )
bob
posted on 23/12/05 at 11:19 AM Reply With Quote
Rolling road is the only way really,its running rich for sure and easy way to see is to check the plugs which will probably look the same as the end of the exhaust.
Wadders
posted on 23/12/05 at 01:27 PM Reply With Quote
Only thing i would add, is that most cars running unleaded seem to have sooty tailpipes
to a certain degree.
Al.
andyharding
posted on 23/12/05 at 02:55 PM Reply With Quote
If the carb has an anti-run-on valve make sure it's connected to a +ve feed when the ignition is on. With the standard Weber carbs the engine will run without this but it won't idle below about 1200 RPM and will need setting up super rich.
Now I figured that out I need to figure out how to get it to idle nice with a 3Kg flywheel...
bigandy
posted on 23/12/05 at 03:37 PM Reply With Quote
Both our tin tops have really black sooty exhausts....
They're diesels though
Dammit! Too many decisions....
jimmyc123
posted on 24/12/05 at 01:04 PM Reply With Quote
cheers guys,
the carb is a webber 2v which is in the hayes manual that came with the donor car.
ill get it looked at as soon as i can.
i took it out yesturday and must havce used about 6 or 7 quids worth of fuel on a 12 mile journey, ( i was nailing it tho :-) )
