Author: Subject: Dipstick... where does it attach?
donut
posted on 5/1/06 at 02:14 PM Reply With Quote
At the end of my dipstick i have a flat hook type afair that obviously bolts up to something but what? With the carb on it can sit tight up against the inlet manifold but theres nothing for it to attach to.
Any ideas?
Image deleted by owner
[Edited on 5/1/06 by donut]
mookaloid
posted on 5/1/06 at 02:25 PM Reply With Quote
Oooh lucky you having a dipstick tube with a bracket!
Mine doesn't have one and it just flopped about till I glued it in one day
Make a bracket after you have got rid of that horrible carb and manifold and put twin 45 's or bike carbs on
Mark
stevebubs
posted on 5/1/06 at 02:52 PM Reply With Quote
Does it not come up through the gap in the carbs and bolt directly to the engine? That's how they're normally attached...
cryoman1965
posted on 5/1/06 at 03:02 PM Reply With Quote
Mine has a hole with a rubber insert. It is positioned out of shot just to the right. The hole is in the throttle linkage bracket.
donut
posted on 5/1/06 at 03:36 PM Reply With Quote
I think i'm just going to bolt it to that hole over to the right.I don't think that hole is needed so that would solve the problem.
