Author: Subject: Some help with R1 carbs?
malinovc
posted on 6/1/06 at 02:32 PM Reply With Quote
Hi!
Would anyone know what is the pipe in the pic below?
Thank you!
Jan
zxrlocost
posted on 6/1/06 at 02:34 PM Reply With Quote
its your fuel in mate
k33ts
posted on 6/1/06 at 02:40 PM Reply With Quote
rubber
sorry im bored
[Edited on 6/1/06 by k33ts]
malinovc
posted on 6/1/06 at 02:47 PM Reply With Quote
Hmm, so the upper two are fuel out?
Jan
zxrlocost
posted on 6/1/06 at 02:50 PM Reply With Quote
theres a pipe on the bike that is an overspill pipe someone else will confirm
theres no fuel return on the 99 r1 though so the only fuel pipe that actually plugs into something is that middle one which then goes onto the fuel pump
malinovc
posted on 6/1/06 at 03:03 PM Reply With Quote
The carbs are from a 2001 bike.
So you say the brass pipe fitting at the bottom is the fuel pipe. But it's funny that the upper two pipes smell of petrol too?
Thank's!
Jan
oliwb
posted on 6/1/06 at 03:05 PM Reply With Quote
The pipe at the top (I believe) is the vacuum pipe to control the diaphragms....the bottom connector will be your fuel pipe, no return on bike carbs! Bogg Bro's have told me to just connect up the fuel pipe and not to worry about the others (leave them to atmosphere....the pressure difference in the manifold will control the variable venturi's) HTH Oli.
malinovc
posted on 6/1/06 at 03:16 PM Reply With Quote
OK, thank you!
Jan
zxrlocost
posted on 6/1/06 at 03:27 PM Reply With Quote
so the one in the middle is for fuel in which i said all along
jimgiblett
posted on 6/1/06 at 03:53 PM Reply With Quote
The two pipes marked fuel in your pic are float chamber air vent hoses. They should "T" together and vent to atmosphere.
The brass inlet marked with a question mark is the fuel inlet.
Jim
