LEMTECH
| posted on 22/2/03 at 11:06 PM |
Radiators
I need a radiator measuring about 400mm long 250mm high for a car i`m building.Does anyone know of any vehicle with a rad of similar dimensions or of
any companies that make reasonably priced rads.
thanks
andyd
| posted on 22/2/03 at 11:16 PM |
Not sure what the dimensions are ('cause I'm sitting here typing this and not in the garage) but I've just got a rad from a bike (CBR1000) I think
and it's fairly small. I'd reckon that it'd be roughly the size you say you need.
If I remember to measure it tomorrow I'll let you know how big it is.
LEMTECH
| posted on 23/2/03 at 10:28 AM |
thanks , if you do measure it can you measure what size hoses it would use please.
andyd
| posted on 23/2/03 at 04:05 PM |
Ok, I've measured it and it is roughly 43cm wide and 23cm high (excluding mounting flanges) and the internal bore for the pipe work is roughly
25mm.
Not sure what the capacity of it is yet as I've not had chance to check.
HTH
BTW: I got it from Colchester Motorcyles (http://www.colchestermotorcycles.co.uk)
[Edited on 23/2/2003 by andyd]
LEMTECH
| posted on 23/2/03 at 06:58 PM |
thanks for that
