Oliver Coles
| posted on 20/1/06 at 08:53 PM |
Audi/MG engine and transmission
Hi
Is it possible to couple a MGB overdrive gear box to a 1987 Audi 80 1800 engine?
Thank you
Only 16 and i have already had my midlife crisis
SeaBass
| posted on 20/1/06 at 09:06 PM |
anythings possible... This must be the weirdest combo I've ever heard though.
Don't know - but the MGB box is big -- very big in overdrive form but it has been fitted into a Locost chassis. For mating it to other engines
the trouble is the B box has a cast in bellhousing so the adpator would have to be a plate type.
I know Golf engines can be mated to type 9s at using a bellhousing.
Or if you wanted to use the MGB gearbox -- the Rover 2 litre Twin Cam M16/T16 or single cam O series can be mated to it.
paulf
| posted on 20/1/06 at 09:11 PM |
I may be possible to use the rear engine plate from a B series engine by redrilling the plate to suit the Audi engine. The plate has an acurately
centred hole for the rear oil seal which could be used to help with the alignment. I considered this to fit an Alfa twincam to an MGB box but never
got around to doing it.
Paul.
quote: Originally posted by britishtrident
For mating it to other engines the trouble is the B box has a cast in bellhousing so the adpator would have to be a plate type.
MikeR
| posted on 21/1/06 at 12:16 AM |
i've got to ask why ?
| posted on 21/1/06 at 04:18 PM |
I can understand the logic
The MG box is actually quite a nice strong box and the ratios ain't bad, gear change is excellent --- overdrive 3rd is a very handy when
waiting to pass traffic -- slip into OD 3rd find a gap then just flick of switch needed to go down to 3rd --- just like kick down on an autobox but
instant.
--- quite a lot of B boxes around from 5 speed conversions.
MikeR
| posted on 21/1/06 at 04:25 PM |
ok,
knew nothing about them, imagined that they'd be old, tired and not very strong.
Why would you put a five speed conversion in if you've got overdrive on 3rd and 4th?
| posted on 21/1/06 at 10:26 PM |
Overdrives tend to stop working, mainly due to neglect, and to have them overhauled is expensive.
I like driving my dads's 'B. The overdrive is really quite a uselfull toy, but I can confirm that the gearboxes are very heavy after
helping him take it out a while back.
