tri
| posted on 21/1/06 at 07:27 PM |
help me
We went to have a play about in car today and once it was out of garage we started it up to drive it but once the engine was under load it just died
and alot of grey smoke came out of the carb what could cause this????
Tri
| posted on 21/1/06 at 07:32 PM |
First thing is line up the timing marks and check the cam belt hasn't lost teeth.
tri
| posted on 21/1/06 at 07:36 PM |
Would that cause it to die only once you lift the clutch it will sit and rev for hours if left but once it goes to move the car it gives up
Tri
[Edited on 21/1/06 by tri]
| posted on 21/1/06 at 08:04 PM |
Sounds like the carb's gobbed. Clean the jets out and try again, does it rev when you choke it?
tri
| posted on 21/1/06 at 08:12 PM |
its a automatic choke but the engine revs ok
Chippy
| posted on 21/1/06 at 11:50 PM |
Sounds like it could be either ignition, or valve timing to me. If either of these are out you can get the engine to rev, but as soon as you apply
load it will just die. I would check the timing before doing anything else.
gazza285
| posted on 22/1/06 at 12:27 AM |
Sounds like the main jet is gummed up to me. Has it been stood at all?
tri
| posted on 22/1/06 at 08:23 AM |
The engine has been lying for a while and only run very occassionally. Would carb cleaner do or do I need to strip it down.
Tri
