greggors84
| posted on 22/1/06 at 04:47 PM |
Timing for tuned Pinto
Does anyone know the what the timing should be for a tuned pinto with fast road cam (Kent FR32)?
Im getting a back fire through the carbs low down the rev range so want to check the timing first before I adjust anything else.
Chris
The Magnificent 7!
mookaloid
| posted on 22/1/06 at 05:11 PM |
I would start at about 12 degrees BTDC.
However if you are using a standard dizzy with just the vaucuum advance disconnected, the advance curve will be all wrong and it won't run all
that well.
Backfiring through the carbs is often a sign of over advancement of the ignition.
HTH
Mark
greggors84
| posted on 22/1/06 at 07:19 PM |
The dizzy, i got with the engine and is matched to the cams. Its a non vacuum one.
Hopefully it is just the timing, i did set it up at idle with a timing light but never checked the advance. I did think the rough running was to do
with the carbs, but hopefully its just the timings out.
Chris
The Magnificent 7!
