Author: Subject: DIY static engine balancing
posted on 16/2/06 at 11:14 AM Reply With Quote
Let's say you have a modern engine, 1990, from Vauxhall or Ford.
Would there be any benefit in balancing the reciprocating parts (con-rods + pistons + rings + big end bolts) yourself or are they ok from the factory?
Method would be to put each on digital kitchen scales, weigh and compare.
Where would be the best place to remove metal from?
And is there any way dynamic balancing can be done DIY style?
BKLOCO
posted on 16/2/06 at 11:51 AM Reply With Quote
My first comment would be that kitchen scales would be nothing like accurate enough to balance an engine.
Lippoman
posted on 16/2/06 at 11:53 AM Reply With Quote
Factory balancing is usually OK if you do not intend to increase the redline or run it at the redline for long times. For some engines (Rover K-series) the factory balancing is better than many aftermarket speed shops.
Lightening parts should not be done if not balancing dynamically afterwards.
Conrods should be weighed each end (big end/piston end). The ends are also usually the best place to remove material.
Usually, balancing and dyno work are the most efficiently spent money if seriously tuning an engine, in regard to power, driveability and endurance.
I've seen many engines where the expected power and torque range were not reached due to not taking the time and cost of dyno, and others where endurance problems were encountered due to not balancing.
[Edited on 16/2/06 by Lippoman]
NS Dev
posted on 16/2/06 at 12:02 PM Reply With Quote
Kitchen scales accurate to 1 gramme (which a lot of decent digital ones are) will be fine for balancing.
As for actually doing the job, look on John Beardmore's site for inspiration (he posts on here as JB)
www.beardmorebros.co.uk
bernie955
posted on 16/2/06 at 12:05 PM Reply With Quote
You don't want to balance the rings and rod bolts. You can balance the pistons with rings fitted if you wanted but most weight differences will be with pistons and rods mostly. Also, rods are usually balanced from end to end i.e. big end and small end are done separately. Rods usually have pads at top and bottom you can remove material from (I have experience with Chevy V8s) and pistons can have material removed from areas inside the skirts. These days piston sets should be pretty close with modern manufacturing techniques.
Crank is normally balanced as well but you can't really do that at home. Weights are added to cover piston/rod weight and the crank is spun to identify where it is out of balance.
You'd also need to have fairly accurate scales to do it properly. Even 1 gram spinning at 6500 rpm can be applying Kgs of out-of-balance weight.
bernie955
posted on 16/2/06 at 12:08 PM Reply With Quote
I forgot to mention you should balance the rods with rod bolts included. It's dangerous to remove material from the bolts (weakens them) or any areas other than previously mentioned. Removing casting flash from rods can reduce the possibility of cracks forming as well as these are areas where stress can be concentrated.
mark chandler
posted on 16/2/06 at 12:31 PM Reply With Quote
I cannot see why you need accurate scales as this is a comparison between lumps of metal. If the scale reads 20 grams out so what, each piston will apear 20 grams heavier than it is !
Surely all you are looking to do is make all the pistons and rods the same weight, you could do this with a simple balance.
It would not hurt to do this.
For a 4 cylinder engine with you can balance the crank, clutch and front pulley with a pair of knife edges on the at each end, not as good as a dynamic balance as you will not know how far along the crank to strip the weight but fine for the lumps of metal at both ends.
But then you will probally be mor dillegent than a machine operator so should get an equivilent result.
Regards Mark
bernie955
posted on 16/2/06 at 12:41 PM Reply With Quote
I meant that the scales should be able to measure fairly small increments, not be accurately reporting actual weights. Static balance should be pretty easy to obtain but rotating balance I'd leave to the experts.
posted on 16/2/06 at 12:42 PM Reply With Quote
Repeatability is an issue with kitchen scales --- Maplin have some nice scales on special this month -- and other nice gear too including a very nice Multimeter with PC connection.
posted on 16/2/06 at 02:43 PM Reply With Quote
can't quite picture this - can you expalin a bit more about the placement of the knife edges (you forgot the flywheel in there! )
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 16/2/06 at 06:46 PM Reply With Quote
Balancing
As Mr NSDev has mentioned it is quite easy to balance your own rods and pistons.
Balance is the word, you do not weigh them but balance them. This page shows the basic idea.
http://www.beardmorebros.co.uk/website%20pages/new_project_engine_page1.htm
If you use this method check for repeatability. Try to balance the rods with washers on the end. Then dismantle everything , reassmemble, reposition etc and see if you get the same result. If you can not get good repeatability then do not try it yourself.
John
BKLOCO
posted on 16/2/06 at 06:57 PM Reply With Quote
Bull
They may read to 1 gram but that does NOT make then accurate to 1 gram
Cousin Cleotis
posted on 16/2/06 at 07:40 PM Reply With Quote
all inline fours will vibrate without a balance shaft. a few grams out of balance will only make a few kilograms of force at high engine speeds, nothing compared to the few tonnes of force created during combustion. is it really worth it?
Paul
posted on 16/2/06 at 08:16 PM Reply With Quote
Paul
Having seen engines explode at 10000 RPM because the flywheel was swapped for one not balanced to that particular crank I would disagree.
gazza285
posted on 16/2/06 at 08:49 PM Reply With Quote
Granted, but only an idiot or somebody going all out and bugger the costs would build an engine to rev to 10,000rpm and not use balanced components.
I would be surprised if DIY balancing on a modern engine would improve things past the factory tolerances, but I can see the point on JB's Seventies/Eighties hybrid Fiat engine, as I could see the point of having my own engine (Crossflow)dynamically balanced
Cousin Cleotis
posted on 17/2/06 at 01:34 PM Reply With Quote
would somebody thinking about DIY balancing also be building an engine to rev to 10,000rpm? i doubt it.
Paul
posted on 17/2/06 at 04:15 PM Reply With Quote
Paul
Once the frequency of the out of balance forces hits the cranks resonant frequency, amplitude gets out of hand quite quickly. This is why crank dampers are so important, and why aftermarket billet alloy crank pulleys that replace them are such a bad idea.
Cousin Cleotis
posted on 17/2/06 at 06:07 PM Reply With Quote
i understand resonant frequencies, but a inline 4 without a balance shaft(or two?) will always vibrate no matter how well they are balanced, so could still match the resonant frequency of the crank.
Paul
posted on 17/2/06 at 09:42 PM Reply With Quote
Paul
All engines vibrate an inline 4 isn't bad as long as moving parts are kept light, it is a lot better than most engines.
Balancing shafts don't stop the vibration but only cancel out the external motion of the engine block.
A good four without balancing shaft is smoother than some fours with --- the 2 litre Rover T16 engine without balancing shafts was considerably smoother than Hondas big four that Rover used in the 600 series which had twin balancing shafts.
Prize for the roughest straight 4 goes to Vauxhalls awful 60s/70s slant four Victor engine which tried hard to bounce its way out the engine bay.
A good straight six may be silky sweet at low rpm but at higher crank suffer from torsional vibrations due the long crankshaft.
This is why straight sixes always have massive torsional vibration dampers on the front end of the engine.
All Vee engines have rocking couples -- V12s are sweet enough but a V4 or V6 just should never be made while a V8 is really no better than 2 straight fours,
gazza285
posted on 18/2/06 at 03:01 AM Reply With Quote
Just a shame it pissed oil out, otherwise a reliable enough lump, one of Rovers better efforts.
posted on 18/2/06 at 10:08 AM Reply With Quote
Bull
... but that doesn;t matter providing the scales read repeatedly. As I understand it, the idea to to make the components equal in weight not weigh some pre-determined amount.
posted on 18/2/06 at 10:13 AM Reply With Quote
doh!! why didn't I think of that; obvious when you see it;
just bot up two rods end to end then rest on flat surface.
