Author: Subject: Ford Ka Endura E Head Bolt torque?
NS Dev
posted on 18/2/06 at 04:10 PM Reply With Quote
Can anybody tell me the torque figure and sequence for the head bolts on this engine, and whether they are reusable bolts?
flak monkey
posted on 18/2/06 at 05:17 PM Reply With Quote
This answer your questions?
http://dspace.dial.pipex.com/prod/dialspace/town/pipexdsl/q/aqso55/FEOC/tech/specs.pdf
You can reuse them once only.
Tightening sequence should be as for all other heads, i.e. start in the centre and work your way out tightening evenly as you go.
[Edited on 18/2/06 by flak monkey]
Sera
http://www.motosera.com
ch1ll1
posted on 18/2/06 at 05:23 PM Reply With Quote
auto data book says renew bolts !
(but other site says not but i would !)
if you look at the head (gear box to the right)
9 3 1 5 7
8 6 2 4 10
1= 30 nm
2= 90 deg
3= 90 deg
hope this helps
cheers paul
[Edited on 18/2/06 by ch1ll1]
MikeR
posted on 18/2/06 at 06:29 PM Reply With Quote
head bolts ??????? thought you where doing a service, what went wrong?
froggy
posted on 18/2/06 at 07:35 PM Reply With Quote
snapped a plug off by any chance?
ch1ll1
posted on 18/2/06 at 07:54 PM Reply With Quote
if you have snapped a plug
get a 14mm drill and be very gentle with it !
and when you get past the seal on the plug it will just wind out easy!
but make sure you get all the crap out of the bore
NS Dev
posted on 19/2/06 at 10:49 AM Reply With Quote
Funnily enough.........YEP!!!
Three of the buggers in fact!
Took the head off and drilled/punched the remnants out, chased the threads, now got to reinstall the head...........quick service then!!!!!!!!!!!!!!!!!
NS Dev
posted on 19/2/06 at 10:55 AM Reply With Quote
Cheers Mate!!!
just the job!
head bolts are going back on as everywhere is shut today anyway.
