Author: Subject: webers
splitrivet
posted on 18/2/06 at 08:57 PM Reply With Quote
webers
Just had a horrible thought how the heck do I set up the vacuum advance now Ive got twin 40 dcoe's or do I just leave the advance tube off and reset the timing or would a later non vacuum dizzy work.
Any help would be appreciated.
Bob
DIY Si
posted on 18/2/06 at 09:08 PM Reply With Quote
It may be poss to connect all four port runners together to get a constant-ish vacuum. This works on some engines, but on others still gives a nasty pulse effect which will confuse the hell out of the dizzy. The safest bet is to get a non vacuum dizzy, or if you can stretch to it go for a Megajolt set up. Haven't got that far myself, but MANY others on here seem more than pleased with it.
[Edited on 18/2/06 by DIY Si]
dave r
posted on 19/2/06 at 09:14 AM Reply With Quote
suitable dizzy for sale on rhocar site
http://community.rhocar.org/index.php?showtopic=10406
nothing to do with me thought the guy sellin it is ok
posted on 19/2/06 at 01:16 PM Reply With Quote
Leave it disconnected --- vac advance has zero effect on performance is purely a dodge to allow the running of weaker mixtures at very low loads/throttle opennings to reduce fuel consumption.
in the 60s/70s a common l trick was to remove the vacum capsule and fix a screw through the distributer base plaste to stop it moving.
splitrivet
posted on 19/2/06 at 03:59 PM Reply With Quote
Thanks for the input guys
Bob
