| posted on 20/2/06 at 02:54 PM |
replacing fuel hose with metal pipe
Has anyone done this on a completed car? I know what to do but since the panelling, engine, gearbox, prop. etc. are in place, I am wondering how
tricky it is going to be to get to the transmission tunnel and add fittings.
What are the chances of there being access from the top with the transmission tunnel cover removed or should I try to jack up one side onto ramps to
get it from below?
JAG
| posted on 20/2/06 at 02:59 PM |
My fuel pipes/brake pipes and wiring loom run along the TOP of the transmission tunnel and I have made a half-round cover, in Aluminium, to close it
all in. The cover fits from inside the car. There are pictures in my archive area.
You could try something similar.
Justin
Kissy
| posted on 20/2/06 at 03:09 PM |
If you go to copper or Cu/Ni please make sure you can support it at frequent intervals otherwise you run the risk of cracking.
DarrenW
| posted on 20/2/06 at 03:29 PM |
Other option is to use braided fuel line. This is what i have. Still needs to be clipped up tho of course but easier to route. Access depends on your
car. If you can remove transmission tunnel panels i guess it will be a lot easier.
You seem to be having to redo a lot of work with your part finished project. Sounds like you are having fun tho'. Nothing beats doing it
properly. Im reaping the rewards now - no problems after 3 monthe and 500 miles on the road.
| posted on 20/2/06 at 03:35 PM |
A lot of it is ok (apart from the tack rods) but I like to do things properly and that is what takes time. An example is finding the hose cable tied
to the brake pipe bracket on the diff; common sense would be to tie it to the body work; would have been no extra effort to do that.
I can just leave the fuel hose in there but metal pipe will last for ever and save a few g's; neater too.
I won't really know how hard/easy until I tray it; but someone here I would have though has tied to access the trans. tunnel after building.
| posted on 20/2/06 at 07:59 PM |
Have you thought about flexible plastic fuel pipe? easier to work with and light.
Mark Allanson
| posted on 20/2/06 at 09:10 PM |
I tried plastic first, which was my first build disaster, it will not bend well at all, it kinks without warning, springs out of the retaining
clips....
I used galvanised steel in the end, which was hard to bend, but stayed where I put it and is very strong. I was very pleased with the
results.
| posted on 21/2/06 at 11:47 AM |
Not so much of a question what to use - I have the kunifer fuel pipe - more of whether I can fit it from the tip or from below.
