Author: Subject: Zetec TPS on bike carbs.
Danozeman
posted on 20/2/06 at 05:07 PM Reply With Quote
Has anyone got any pictures of how theyv mounted a Zetec TPS to a set of bike carbs? Im after some ideas to do mine. The simpler the better.
Dan
dave1888
posted on 20/2/06 at 05:11 PM Reply With Quote
what carbs are you using
Danozeman
posted on 20/2/06 at 05:13 PM Reply With Quote
zx9r.
[img][/img]
Dan
oliwb
posted on 20/2/06 at 05:37 PM Reply With Quote
I've got some zx7r's and had to mount the tps on the bulkhead in a homemade mount and use a second cable to operate the TPS....not ideal so if you can come up with something I'd be gratefull too! Cheers Oli.
givemethebighammer
posted on 20/2/06 at 09:19 PM Reply With Quote
I know it won't help you but my blackbird carbs already had the TPS attached. All I had to do was recalbrate my ECU for the honda TPS range.
They are Keihin VP carbs, the TPS fits on the end of the spindle of the carb nearest the driver. Maybe there is a way of fitting a TPS in the same place on yours ?
Danozeman
posted on 21/2/06 at 06:26 AM Reply With Quote
Thats where i want it to be but I dont know the best way to take a pivot off the throttle spindle.
Dan
