Author: Subject: Type 9 input shaft wobble
Mansfield
posted on 19/3/06 at 07:24 PM Reply With Quote
What are the limits on this?
I reckon I have around 0.75mm (at the furthest point from the bearing) - bearings gone or worse?
ned
posted on 19/3/06 at 07:35 PM Reply With Quote
there will be some play if the gearbox is seperated from the engine - once the two are connected the spigot bearing in the end of the crank will support the input shaft.
Ned.
beware, I've got yellow skin
Mansfield
posted on 19/3/06 at 07:43 PM Reply With Quote
Is my 'wobble' normal then?
Edit - My gearbox is seperate.
[Edited on 19/3/06 by Mansfield]
Dave Bailey
posted on 19/3/06 at 07:45 PM Reply With Quote
I have a gearbox from BGH Geartech that has just had first gear changed. I have about the same movement and they never said there was a problem. They checked everything over when they did the gear change.
Dave B
Mansfield
posted on 19/3/06 at 07:48 PM Reply With Quote
Thanks Ned & Dave, much happier now.
I love this website.
