westf27
| posted on 24/3/06 at 01:24 PM |
steering wheel centre
I have a sparco wheel for sva test,it is not round does that matter?the column is offset for crash and has collapsible boss.Question,spokes are 5mm
radiussed.no holes but not padded does this matter
DarrenW
| posted on 24/3/06 at 02:21 PM |
I used an aftermarket wheel at SVA. No holes allowed (so you are OK there). Rads must meet minimum requirement. If you use aftermarket wheel you must
use collapsible boss.
I hope other VOSA centres allow the same. Worth a call if you need confirmation.
