posted on 28/3/06 at 09:11 AM |
accelerator bunmp stop - ideas
Lookoing for ideas to make a bump stop for the acceleerator pedal; when it is fully depressed , the carbs limit its travel - not good.)
Don't know the best way but either could make a bracket at the top of the pedal to limit it or a bolt in the foot well.
Ideas?
zxrlocost
| posted on 28/3/06 at 09:22 AM |
L bracket riveted through floor with a hole in the L put a nut and bolt through then you can adjust
chris
Mix
| posted on 28/3/06 at 10:29 AM |
Bolt in the footwell would probably allow for easier fine adjusrment as it would be further away from the pedal pivot.
Mick
| posted on 28/3/06 at 04:22 PM |
Threaded run with an L piece so's you don't have to mount on the radius steel.
Like this here on 1st December.
