smart51
| posted on 28/3/06 at 11:35 AM |
fuel evaporation
If I leave my bike engined car for a few days, the fuel pump ticks away for a few seconds before stopping. If you switch the ignition on when the car
has been stopped for a few hours, it doesn't.
Is this because the fuel evaporates out of the float bowls and needs to be topped up?
mookaloid
| posted on 28/3/06 at 11:40 AM |
yup
rusty
| posted on 28/3/06 at 12:22 PM |
Also some ECU's know how long car has run etc so will only let pump run on/ pre run if required.
| posted on 28/3/06 at 04:36 PM |
Won't the line pressure have dropped sufficiently (in a fuel injected setup) enough over a few days for the pump to trigger when restarted? I
think evaporation is unlikely in a sealed system, but back pressure (balancing) is more likely.
[Edited on 28-3-06 by Hellfire]
smart51
| posted on 28/3/06 at 05:57 PM |
the float bowls on my carbs are not sealed. the main jet opens out into the venturi of the carb and the float bowl breathers vent to atmosphere. I
didn't know that fuel would evaporate that quickly.
