Author: Subject: Toyota 4AGE engine position
Errol
posted on 3/4/06 at 06:57 AM Reply With Quote
What is the best position when mounting your engine, in the middle or off set to the left. Bear in mind the the car will only be used for road use and the odd track day.
Regards,
Errol
bimbleuk
posted on 3/4/06 at 11:20 AM Reply With Quote
I can't comment on the Luego chassis but the Striker chassis has the 4AGE offset as standard and with me in it the corner weights are fairly even.
If you drive alone mostly then you'll get a lot of benefit from an offset engine.
