RichardK
| posted on 6/4/06 at 06:15 PM |
Gear lever question
What is this bit and will it cut off, it is just where my remote linkage will weld on.
Ta
Rich
theconrodkid
| posted on 6/4/06 at 06:22 PM |
its a rubber bush inside,angle grinder normally removes it
who cares who wins
pass the pork pies
RichardK
| posted on 6/4/06 at 06:26 PM |
Ah, so it's just there top take away a bit of vibration is it?
Thanks, off to get THE tool out
See Ya
Rich
| posted on 7/4/06 at 06:55 AM |
To put it more technically it de-tunes the gear lever from its resonant frequency.
Heating with a blow lamp will de-bond it allowing easy removal -- but take care the type of synthetic rubber it is made off produces small ammounts
of really nasty acids if burned --- don't get it on your skin, it gets into your flesh he only way to get rid of it is to cut out the
surrounding area of tissue.
[Edited on 7/4/06 by britishtrident]
caber
| posted on 7/4/06 at 07:44 PM |
If you hold the bottom of the lever in a vice and apply brute force to the top secton you can get it to shear, burning it out is not very clever as
the burnt elastomer is very very nasty.
Caber
| posted on 7/4/06 at 08:02 PM |
Saw it off above and below and weld it back together at the length you want. While you're at it go to Dave Andrews page and use his quickshift
tips on it, really makes a difference as in big improvement.
