Author: Subject: intelligent fuel pump?
posted on 7/4/06 at 11:55 AM Reply With Quote
In the land rover I have a facet fuel pump that is powered all the time when the igntion is on.
Iam wondering whether an electrical pump exists that pumps petrol according to the demand of the engine?
A simple circuit driven off the igntion coil so the pump pumps more at higher rpm would be easy to tonk up; a more sophisticated version would use throttle position to increase the pumping according to engine loading.
the advantages are quieter operation, longevity and less power drawn (ok, the last one is miniaml but it all counts!)
muzchap
posted on 7/4/06 at 12:03 PM Reply With Quote
but if it goes wrong... then it's a dead pump!
Quiter operation - if ya can hear the fuel pump over the zorst - fair play
Your pump - give it a go ;-)
and more importantly
GOOD LUCK (if it works - I'll have one )
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
greggors84
posted on 7/4/06 at 12:24 PM Reply With Quote
You would have to make it so it pumped more or less depending on engine speed/throttle position instead of just coming on or off.
Not sure if you can get a variable pump. If you can then im a system has been designed as otherwise variable pumps would exist (if they do!)
Chris
The Magnificent 7!
oliwb
posted on 7/4/06 at 01:41 PM Reply With Quote
What about a motorbike fuel pump such as one from a goldwing?? They pump to a specific pressure and then cut out like an SU pump....obviously the less the engine is revving the less demand for fuel so the pump reaches its threshold pressure sooner and cuts out, then when your ragging it its on all the time....also removes the need for a regulator and prevents overfilling of the fuel bowl and subsequent flooding.....Clever stuff! Oli.
procomp
posted on 7/4/06 at 02:02 PM Reply With Quote
Hi they do. Facet interupter type one.
cheers matt
JAG
posted on 7/4/06 at 02:07 PM Reply With Quote
Isn't this what more recent fuel injected petrol engines do - that's why they don't have a fuel pressure regulator or fuel return line to the fuel tank.
The pump supplies just enough fuel at just the right pressure hence all fuel delivered to the engine is consumed whilst keeping the pressure with certain tolerances.
Justin
posted on 7/4/06 at 02:22 PM Reply With Quote
Old SU pumps worked on demand. when there's no pressure they pump, then they cut out till it drops again, nothing complicated though just pressure activated.
posted on 7/4/06 at 03:06 PM Reply With Quote
cheers matt
ah, I forgot one important bit of info., it is an open system so fuel is continuously pumped back from the carbs into the tank (stops air locks apparently) hence this would not work for me.
posted on 7/4/06 at 03:25 PM Reply With Quote
The fuel pump in my MR2 turbo switches tro a low power mode at idle, though this is controlled by the ECU. It just switches a relay which puts a big power resistor in series with the pump. Locost method would be a microswitch on the throttle pedal I guess...
silex
posted on 7/4/06 at 04:57 PM Reply With Quote
One of the electronics wizzez on the site might know better, but using a potentiometer on the throttle pedal into a 555 timer or similar you should be able to create a PWM (Pulse Width Modulated) signal to the pump. This would act like a variable speed controller to the electric pump (I think).
You would need to put in a high power transistor or FET in the circuit to handle the current of the pump but I think it would work.
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
Johnmor
posted on 7/4/06 at 04:59 PM Reply With Quote
Fuel Pump
Alfa engine ECU,s only switch power to the pump when the engine is turning, and will not supplly power only if the ignition is on, prevents pump wear and means that if you have a accident the pump is switched of if the engine stops.
Means you dont need an impact cut off switch.
Detection is from the ignition timing pickup and switched through a relay.
Dont know if this is much help.
RazMan
posted on 7/4/06 at 05:21 PM Reply With Quote
That is how my MBE ecu trigger my Landy fuel pump - Ignition on (give a 2 second prime) Engine start (starts pump) Engine stall (stops pump)
Raz
the_fbi
posted on 7/4/06 at 05:52 PM Reply With Quote
I believe thats the same for XE's too, unless there is a crank signal the pump doesn't operate.
posted on 7/4/06 at 05:53 PM Reply With Quote
Most fuel injected cars do this. They often allow the pump to run for a second or two when you switch the igntion on to build up pressure in the fuel rail ready to start the engine.
Silex, you could do that but I'm not convinced the extra complexity is worth it on a 7. If the fuel pump is particularly noisy then it might be worth slowing it down at idle, but unless you have a particulary quiet 7 when as soon as you start driving the engine and wind noise will drown out most things.
By the way, I suspect the only fuel pumps that can be successfully slowed down this way are rotary based ones that take a continuous current ( i.e. with a motor) rather than the oscillating plunger type that takes current in short pulses.
Syd Bridge
posted on 7/4/06 at 06:16 PM Reply With Quote
I would think that you are correct Mike, regarding the rotary vs pulsed.
Although this discussion is somewhat academic, a pulsed pump could be controlled with a 555 firing a transistor in the pump feed. If you put a variable resistor in the timing side of the 555, the pulse frequency could be varied, ie slow to fast. A pot on the throttle, as in an efi setup may be able to do it.
Syd.
