The Baron
| posted on 12/4/06 at 06:17 PM |
Right Angle Distributor
I need to get hold of a right angled distributor cap for my Pinto ignition.
I am convinced that I have heard or read somewhere that a Peugeot one fits the Ford Bosch distributor.
Any body know the part number, or am I talking or thinking c**p
Cheers in advance,
The Baron
flak monkey
| posted on 12/4/06 at 06:29 PM |
Theres one on ebay at the moment, I saw it earlier today.
Do a search for pinto. Its on buy it now as well, about £15 IIRC.
Sera
http://www.motosera.com
| posted on 12/4/06 at 06:42 PM |
Try your local motor factors,.probably cheaper
dave r
| posted on 12/4/06 at 08:27 PM |
pug or cossie, sierra owners club forum would know the answer/part numbers
wicket
| posted on 12/4/06 at 09:45 PM |
I believe its a Motorcraft Fiat part for a X-flow, guess the Pinto dizzy might be the same. Don't have a part number I'm afraid.
Have a look at Rusty Nuts post here
http://www.locostbuilders.co.uk/viewthread.php?tid=39349
[Edited on 12/4/06 by wicket]
jonno
| posted on 12/4/06 at 10:19 PM |
Right Angle Distributor Cap.
For use on distributors which normally use a DDB442 straight distributor cap as standard.
This includes all x-flow and pinto Bosch applications & the later smaller diameter CVH bosch distributors.
Typical applications are on x-flow engines so that the leads clear 40s or 45s
http://cgi.ebay.co.uk/Ford-Pinto-X-Flow-CVH-Right-angle-distributor-cap_W0QQitemZ8034606315QQcategoryZ72205QQrdZ1QQcmdZViewItem
Hope this helps
| posted on 13/4/06 at 06:11 AM |
The Ford distributor is lower than the Bosch. Also there are different flavours of twin carb manifolds so depending o nthe angle of the manifold, you
may get away with Ford.
I have 1300 crossflow so lose 1 inch yet managed to fit the leads under the manifold using the smaller lead insulators plus a bit of filing in the
manifold rib. Silicone leads are more bendy than copper cored ones too.
Check to see if you have a problem before shelling out.
