Author: Subject: 5 speed type 9 box to 1.3 x-flow
myeates
posted on 20/4/06 at 09:52 AM Reply With Quote
hi all help required
i am currently building i locost and have decided to put a 5 speed box in
(sierra type 9), the engine is a ford x-flow 1.3 and i have a 1600 x-flow
clutch and flywheel. When the gearbox is fully bolted on the clutch
actuation lever has no play in it i have tried the old escort thrust bearing
but this still does not make it have enough and i have come to a bit of a dead
end.
has anyone come across this before if so please help as its holding progres back
thank you all in advance
regards
mark
MikeR
posted on 20/4/06 at 10:03 AM Reply With Quote
xflow flywheel, sierra 21 spline ...... 7inch? clutch, sierra release arm and bearing
its a well known conversion and will be in the archives if you do a search
ned
posted on 20/4/06 at 10:51 AM Reply With Quote
see zilspeeds signature
beware, I've got yellow skin
Marcus
posted on 20/4/06 at 12:12 PM Reply With Quote
Frankly, I'm surprised you've got as far as that!
In the above scenario, the gearbox input shaft wouldn't have even gone into the clutch plate!
You need an Escort clutch cover and a 1600 PINTO plate (from Capri / Sierra) and release bearing.
The flywheel should have been fine fron your original 1300 (lighter than 1600 too)
Have you fitted a FWD flywheel instead?
Marcus
Marcus
Because kits are for girls!!
myeates
posted on 20/4/06 at 02:21 PM Reply With Quote
thanks guys
i dont know i got given it with the gearbox when i told the scrapyard guy what i wanted and he was building one at the time and said it would be ok. the clutch was only changed to acomodate the larger shaft diameter and then the flywheel changed because the larger clutch would not fit the 1.3 flywheel.
so basically this is a bad combination
regards
mark
irvined
posted on 20/4/06 at 04:26 PM Reply With Quote
I'm using a 1.3 xflow and type 9,
I use the original flywheel and clutch cover, and a clutch from the mk2 escort.
I'm using (I think) A 7.7" 20 Spline plate, the Quinton Hasel number for the pressure plate is C752AF
The release arm and release bearing are from the Type 9.
Check out www.qh.com if you need to grab the QH clutch catalog, it lists the dimensions and splines for the ford clutches and is a godsend when dealing with suppliers.
HTH
http://irvined.blogspot.com
myeates
posted on 20/4/06 at 07:35 PM Reply With Quote
david that sounds good i will have to go and have a look. if your using the original clutch cover and flywheel then that will be great. I will deffinately have a look
regards
mark
