se7ensport
| posted on 22/4/06 at 04:44 PM |
Engine cooling, side vents + cold air induction….
Not sure if I’m worry about this too much for a road/track car, but I’ve nearly completed my Stylus and need have a couple of outstanding issue.
I’ve got twin 45s with K&N bolt on filters in a completely open engine bay (2.0 pinito), I’m yet to even fit wheel arch liners or fit side vents.
I want to ensure that I get the hot air from the rad & engine out and get cold air to the filters, but how?
Option 1 is to run some 76mm ducting from the side of the rad (i.e. cold air) to the filters + put a couple of RS turbo or cobra style vents in the
wings behind the front wheels and box the wheel arches in.
Option 2 alloy panel the floor of the engine bay, add a alloy panel behind the radiator to duct the hot air in to the boxed wheel arches, add side
vents to release air pressure from cold air feed to filter (again 76mm hose from the front) + this will act as an exit for engine and exhaust heat
(note pipes already lagged). See pic for example.
cant get the hang of posting images but the address is:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=ducting.JPG
Option 3 ???
Cheers guys
[Edited on 22/4/06 by se7ensport]
RazMan
| posted on 22/4/06 at 06:09 PM |
  ducting
Option 2 make the most sense to me although if the route from rad to exit is too bendy it might compound the problem. Either way panelling the floor
of the engine bay will improve flow.
[Edited on 22-4-06 by RazMan]
Raz
Simon
| posted on 23/4/06 at 10:33 AM |
You will want ventilation where there is low pressure - ie above the bonnet. This will act as an extractor and make venting that much more efficient.
This should give you an idea of what I mean
http://www.sleepy-fish.com/images/Racing_Green_171004/Sagaris/IMG_0888.JPG
bit drastic, and a lot of work, but's it's one of the mods I'll be doing when remaking my bonnet.
Here's another - http://www.locostbuilders.co.uk/viewthread.php?tid=43376
it's Razman's car
Simon
[Edited on 23/4/06 by Simon]
se7ensport
| posted on 24/4/06 at 12:53 PM |
Razmans looks very cool and not far off what I had planned originally (although that looks a lot neater), I'd also seen something very similar
on a westfield.
The amount of body work + sealing the exit from the back of the radiator to the bonnet had put me off, I might have to get the tape measure out
again....
C10CoryM
| posted on 24/4/06 at 03:22 PM |
For optimal cooling you want high pressure inlet, low pressure outlet. The tires tend to "grab" air and stuff it into the wheel wells
creating pressure. This is why you see wheel arch vents on pretty well all full body race cars. Probably still less pressure than the front of the
car so air will still move at speed, but not as well if you vented to the sides of the body.
The general way to do the underhood ducting is hoses to the inlet of the rad for the engine/brake and exhaust the hot rad air to the sides of the car
(sometimes the top, but sides are prefered IMO)
Hard to do on a street car w/o ruining its pretty lines .
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
