Author: Subject: assembling push fit oil hoses/fttings
ned
posted on 25/4/06 at 05:13 PM Reply With Quote
Been struggling with some 5/8 pipe and steel/ally 'push fit' mocal fittings. What's the knack to assembling these things?
I've already messed up two short lengths and ended up cutting them back off the respective fittings as I just can't get the hose over the 3 ribs on the ends of the fittings. first time was done dry, second time i heated the hose in some boiling water to try and soften it up but still no cigar, whats the best thing to use for a lubricant on the fitting ends?
cheers,
Ned.
beware, I've got yellow skin
owelly
posted on 25/4/06 at 06:09 PM Reply With Quote
Any piccies? I have only ever seen the two piece screw-together hoses or the crimped (swaged) one.
http://www.ppcmag.co.uk
ned
posted on 25/4/06 at 08:02 PM Reply With Quote
these are the babies:
Mix
posted on 26/4/06 at 06:52 AM Reply With Quote
I would give Vaseline a try, washing up liquid may also work but it can have detrimental effects on some synthetics.
Mick
James
posted on 27/4/06 at 11:56 AM Reply With Quote
I was gonna say try vaseline aswell.
has worked for me before on the Golf!
James
ned
posted on 27/4/06 at 12:05 PM Reply With Quote
managed to get them on last night on my second (4th in total) attempt. Hoses in pan of boiling water, welding gaultlets and some gear oil on the fitting ends.
i've not fitted any hose clamps as there's none pictured and as i couldn't physically pull them off and had to cut the hose when i got it wrong i can't see them coming apart. must be the way the ends are designed so they are a bu**er to get on and never come off without destroying the hose!
cheers all,
Ned.
[Edited on 27/4/06 by ned]
posted on 27/4/06 at 12:33 PM Reply With Quote
just push them oh you weedloing!!! I've never had problems with these although mine were slightly different.
I think it is worth the peace of mind for the the price of a jubillee clip, I have them on mine but I do need them.
