Author: Subject: Zetec Pullys and stuff!
Krismc
posted on 28/4/06 at 05:34 PM Reply With Quote
Ive got a version 3 black top 2 litre zetec 1999.
I need some advice on sourcing parts for this engine, ive got a alternater and bracket which needs modifiyingand ive changed the pully to a groved one, oh and a starter motor which rubs the sump and engine- which i think ill be able to rectify!
my question/problem is can people show me there pully configeration! im totally stumped how to make this work!
i need a aux belt not sure where to get one?
do i need a differnt water pump, or is the cooling not a issue with the pump running the wrong way??
here is a pic.....
and you can just see in this pic where i have mounted the alternator..
[Edited on 28/4/06 by Krismc]
theconrodkid
posted on 28/4/06 at 05:41 PM Reply With Quote
you need an escort water pimp,no pas or a/c that spins the right way
[Edited on 28/4/06 by theconrodkid]
who cares who wins
pass the pork pies
Monkeybasher
My car ran a hotter when the pump was going the wrong way, head gasket went then the bottom end all in 1,000miles
I then found out about the pump being different, whoops.
Probably worth doing as the pumps are cheap, you will need a grooved water pump pulley too
Krismc
posted on 28/4/06 at 05:42 PM Reply With Quote
Searching on the internet i found these pictures but im not sure what is what?
And dont know which one is best to follow! my alternator seems to sit a lot higher than the ones in the pic!
the pump issue....
which model escort i dont know?? but apperently turns opposite direction
racelines zetec, obvisly with a scavange pump
sumones off here but i dont know who
and another?
APR
posted on 28/4/06 at 05:46 PM Reply With Quote
you use the existing water pump but add a extra pulley look in photo archive at blacktop engine
Krismc
posted on 28/4/06 at 05:47 PM Reply With Quote
Grooved water pump from where??
you beat me too it, i know i need a escort water pump i was going to say that but does anyone know which one??
Monkeybasher
posted on 28/4/06 at 05:49 PM Reply With Quote
If you run the water pump off the back of the belt its the 2.0l pump you need. If you run the water pump off the inside of the belt its the 1.8l pump.
Simple as that
Krismc
posted on 28/4/06 at 05:53 PM Reply With Quote
yea right ive got that bit sorted i think, i get what you mean now its plain to see, so its just a case of seeing what will fit, adjusting the alternator bracket to fit snug, then adding a extra pully!
....right now im worring
Dusty
posted on 28/4/06 at 07:02 PM Reply With Quote
Krismc, you can see in the bottom two pictures of your second post that the blacktops use an idler over on the nearside and keep the blacktop water pump. Thats because you can't change it for a pump from a silvertop cos they don't fit, escort or otherwise.
BKLOCO
posted on 28/4/06 at 07:05 PM Reply With Quote
I was gonna say that
Krismc
posted on 28/4/06 at 07:25 PM Reply With Quote
really, cheers i was just on ebay looking for a pump!
thats the way ill do it then eh! how solid will it have to be mounted??
zetec7
posted on 28/4/06 at 09:16 PM Reply With Quote
zetec pulleys
We just made brackets to relocate the OEM tensioner pulley to the left side of the engine, giving the belt lots of engagement around the water pump pulley. Brackets made out of 3/16" auminium. Works great
theconrodkid
posted on 28/4/06 at 09:45 PM Reply With Quote
forgot about it being blacktop,pumps are made for cateringvans i belive or 1 is suitable for USA blacktops
who cares who wins
pass the pork pies
Krismc
posted on 29/4/06 at 08:19 AM Reply With Quote
zetec 7
just checked your archive and your zetec is pretty darn nice.......
....can i have it!
super7
posted on 29/4/06 at 09:55 AM Reply With Quote
I have some images in my photo archive.
On my rebuilding.
Krismc
posted on 30/4/06 at 04:14 PM Reply With Quote
cheers ill check them out
