Krismc
| posted on 1/5/06 at 04:31 PM |
Flywheel bolts for Zetec - pinto
....ive got a 2 litre zetec unit and got a flywheel from a pinto lightened and balanced, i was told i would require the bolts to be shorter, spacers
put in between or replaced with shorter ones from a automatic! due to the fact the original ones are too long and lock the crank- asked at a few nut
and bolt places and they dont do them, i tried ford and the cant help without me telling them exactally what car!!
does anyone know which automatic flywheel had the 2-3mm shorted bolts than than 2.0 zetec!
cheers kris
Krismc
| posted on 1/5/06 at 04:41 PM |
took the bolt and he couldnt tell me the sizes on the computer only the part numbers, plus all auto stuff is special order!
so if i buy the wrong ones ill be stuck with them!! and they aint cheap and i dont fancy lobbing a bit of the ends on such a lightened and balanced
piece of equipment
[Edited on 1/5/06 by Krismc]
Markp
| posted on 1/5/06 at 04:44 PM |
I just took 5mm off the ends. works treat!!
Mark
Krismc
| posted on 1/5/06 at 04:56 PM |
right so cut sum off and loctite them in and forget about it !!!
ill give it a try then!!
big_wasa
| posted on 1/5/06 at 08:04 PM |
Or send us a self addressed jiffy bag and ill give you a s/h set of 6.
they want a good clean as they have been in my nuts and bolts tin for a year or so. And will want a good smear of thread lock to avoid an oil leak.
Pic shows 6 short ones infront of four longer ones. From an auto Mondeo
Krismc
| posted on 2/5/06 at 03:20 PM |
your a bloody star!!
