Krismc
| posted on 1/5/06 at 04:40 PM |
3.162 LSD DIFF OIL!
where to buy and how to fill up??
Went to halfords and a few other motor factors to buy the above, but all the castrol etc decent stuff and own make stuff said not suitable for
LSD's!
Where do i buy LSD oil??
and when im topping it up how do i make sure i dont put too much in, if i top up via the bleed/vent pipe and just crack the fill bolt of will this be
ok?? i have no room to fill normally via the fill bolt!
highspeeddirt
| posted on 1/5/06 at 05:03 PM |
You don't need LSD oil with Ford viscous diffs only clutch plate type LSD. I used castrol EP90 I think.
Fill to the bottom of the filler hole. I guess if you fill through the breather with the normal filler plug removed then once it starts coming out of
the filler that will be fine.
Krismc
| posted on 1/5/06 at 05:10 PM |
thought so!!!
nd you sure about the Diff oil!?
Tangerine Scream
| posted on 1/5/06 at 06:30 PM |
Surprised me as well but yep, plain old EP90...luckily I buy it in great quantities for the Landy
Krismc
| posted on 2/5/06 at 03:26 PM |
cheers then
Liam
| posted on 2/5/06 at 04:01 PM |
Yeah - normal oil cos the viscous coupling is a sealed unit.
Liam
