greggors84
| posted on 3/5/06 at 12:16 PM |
Liquid Gasket
What a good and well known brand of liquid gasket?
Im not using it, my housemate has designed a Formula Student gearbox for his Masters project and needs to know a decent brand. Just for his write up
really.
Chris
The Magnificent 7!
Kissy
| posted on 3/5/06 at 12:26 PM |
I would not use instant gasket if I could avoid it. If I had to use silicone I would just use a high modulus bathroom sealant. What I would do is
cut paper/fibre gaskets and use a very thin smear of Hylomar (Hermetite) Blue, or Golden if it can be found.
Nick Skidmore
| posted on 3/5/06 at 02:10 PM |
Wellseal, you can get it on Ebay about £10 a tube.
A very good sealant that does not fully set and does not form 'strings' that can fall off on the inside and block oilways.
NS Dev
| posted on 3/5/06 at 02:16 PM |
Yep, Wellseal or Rhodorseal
| posted on 3/5/06 at 02:30 PM |
Loctite do a grade that hardens Rover used it very effectively on the K series engines which were a more or less gasketless design.
Rover part number was GGC 108
