Author: Subject: BIKE THROTTLE BODDIES!
Krismc
posted on 3/5/06 at 03:02 PM Reply With Quote
Got these GXSR throttle boddies and im going to run standard injectors, im totally unsure how to get these fitted to my zetec!
I need a manifold making- where and who can do this?
can anyone advise me ive been looking about in search field but all other TB's seem to be different!
and what should i do as reguards seperating them and fuel supply etc!
any help is appriciated?
pics to folllow
Krismc
posted on 3/5/06 at 03:06 PM Reply With Quote
[Edited on 3/5/06 by Krismc]
DarrenW
posted on 3/5/06 at 03:08 PM Reply With Quote
U2U sent ref Deneo
Krismc
posted on 3/5/06 at 03:17 PM Reply With Quote
cheers ive sent him a U2U - so i may have the manifold sorted can anyone tell me anything else i would need, i would like to try and get the stuff ordered ASAP- like the filters, hosing joints and pipe work, throttle linkage etc
James
posted on 3/5/06 at 04:19 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=8100&page=4
Read this thoroughly, tells you most of what you need.
HTH,
James
Krismc
posted on 3/5/06 at 05:34 PM Reply With Quote
great but most the file links and the jpegs no longer exsist and im no further forward as people contradict each other or is it just that there is more than one way to skin a cat??
all i need to know is how to dismantle the unit, what do i keep?
what do i need to put back together and do i need a special throttle linkage and sensor??
muzchap
posted on 3/5/06 at 06:07 PM Reply With Quote
Kris,
Slow down mate
Paul's sorting you out some stuff already - he'll advise on what to do.
You do need a custom manifold - so best to send your TB's off to a company to make one - and the gasket for the inlet manifold - that's how I did mine.
You'll then need to connect together - I used 45mm pipe from Burton Power and 2 jubilee clips to do mine from Inlet ---> TB. then 52mm pipe for TB ---> Trumpets, again with 2 jubilee clips.
Next get some Aluminium Trumpets from www.performancecentre.co.uk - you want the ITG Bare Spun Aluminium (bout £5.00 each).
You'll then need a new fuel rail - with an inlet and outlet 8mm pipe. Jenvey supply fuel rails for about £20-£30 - you just have to cut it for your injectors.
You'll also need a Fuel Pressure Regulator - Ebay is a good bet - or new for about 60-70quid.
Keep everything standard - fuel pipe is 8mm.
The clips you want are fuel hose clips - Car Builder Solutions or Merlin Motorsport - or local motorfactor.
Don't dismantle the unit - you need pretty much everything on there
It's best to research everything carefully and approach with caution - this is not a 'bolt together' solution - I've just done all the above and found out my fckuing alternator won't fit under the TB's!!!
But - when it is complete the sense of achievement and satisfaction is immense (so I'm told )
[Edited on 3/5/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Krismc
posted on 3/5/06 at 07:00 PM Reply With Quote
Slow down mate
yea i know paul is sorting the elctronics parts!
sorry mate just nothing has got done on my car in weeks! so im itching to get it sorted!
yea fuel pumps, filters, ecu, wiring loom etc- all being sorted by him, he seems a good chap
didnt relise he knew his stuff on the throttle boddies as well
deneo is helping me out there hopefully, he seems to do some superior welding
Any size trumpets do??
And you know the lenght of pipe roughly i make it 25-35mm should do it, is that about right just my mate is going to get some custom samco done for me in orange and it takes 5 weeks!
thats why im worring about time
any special regulator or just a FSE desinged for a ford
cheers for that and good luck with the rest of your build
Krismc
posted on 3/5/06 at 07:20 PM Reply With Quote
just had a look on www.performancecenter.co.uk
and seen these with no pic but i take it mean 48mm internal diameter and 70mm in lenght!!
Part No. AH32
Type Bare aluminium spinning
ID 48
Length from carb 70
Notes For customer fabrication
Price £5.46
resonable price
muzchap
posted on 3/5/06 at 08:06 PM Reply With Quote
Yup they're the ones
I know ya eager mate - so am I - it's just more annoying buying loadsa stuff that AINT needed, because things were rushed or not properly researched
I'll help as much as I can - doing a similar install.
I'd advise trying to go and see a car with the install done - or near to done - you'll come away with a much better picture of requirements then
Krismc
posted on 4/5/06 at 06:40 PM Reply With Quote
Dont know anyone in northeast who has one? Didnt know it was possible until you guys told me!
And was i roughly right about the pipe lenght and size?
My (rough) list so far
1) PIPE 30mm x 52mm (x4)
2) PIPE 30mm x 45mm(x4) in samco!
3) 16 jubilee clips (smooth pipe type)
4) fuel regulator?? (which one)
im going to try and keep the spacing on the bike TBs the same and im not going to split them!
[Edited on 4/5/06 by Krismc]
DarrenW
posted on 4/5/06 at 10:38 PM Reply With Quote
Kris,
When speccing the pipes say which is diameter (the other will be assumed to be length).
Im pleased Deneo will be able to help you out (i dont suppose he mentioned my manifold did he?)
If you are going for throttle bodies will you also need a swirl pot adding to your list? May also need oil catch tank (Deneo should be able to sort you out)
Krismc
posted on 5/5/06 at 02:25 PM Reply With Quote
what is a oil catch and swirl?
And where do they fit??
and yea he said possibly next week for your manifold, i only spoke to him about it, i dont think is making me one- not sure
Krismc
posted on 5/5/06 at 02:46 PM Reply With Quote
ah i cant use samco cause apparently it isnt fuel resistant!
