Author: Subject: Micra rad - alternative fan swithes
DarrenW
posted on 5/5/06 at 09:36 PM Reply With Quote
Where is the best place to buy alternative thermostat fan switches for Micra rads. Im hoping all rads have a std thread size and marked up with the temp at which they turn the fan on.
My fan kicks in at 98deg and off at94deg (as indicated by Digidash2 Pro and std temp sender in pinto head). Id like the fan to kick in at approx 88deg.
Thanks for advise?
for those who followed my bonnet vent thread - it looks like the vents havent made a jot of difference so id like to lower coolant temp that an kicks in next.
RazMan
posted on 5/5/06 at 09:48 PM Reply With Quote
Just a thought ..... I had a cooling problem when I put a body kit on my Nissan 200SX. It turned out to be airflow problems - eddy currents generated behind the front section prevented air going through the rad. I panelled out the void between front bumper and rad, forcing the air to take a direct route ...... problem solved with a sq ft of ally plate
Raz
the_fbi
posted on 5/5/06 at 09:52 PM Reply With Quote
Have you had it setup on a rolling road?
Having the timing too far advanced can cause the engine to run overly hot.
posted on 6/5/06 at 07:55 AM Reply With Quote
Go to your local friendly motor factors , they should be able to tell operating temperatures for fan switches . MOST fan switches use the same thread . As already suggested in another thread try a bottle of water wetter.
tim windmill
posted on 6/5/06 at 08:00 AM Reply With Quote
darren you could get a manually adjustable one where you can set the fan to come on when you want.you wouldnt have to worry about the thread size etc as these are externally mounted with a capillary going into the water circuit.
cost about £20 and work very well, got ours from a show the other year but cant remember the name of the company.
posted on 6/5/06 at 08:45 AM Reply With Quote
Couple of things we did to reduce running temperature.
1 - Setup properly on a rolling road.
2 - Add water wetter to coolant
3 - Use expanding foam in nosecone to fill voids (top, bottom and sides) thereby directing all airflow through rad.
4 - Bonnet Vents
Problem solved.
Phil
DarrenW
posted on 6/5/06 at 11:03 PM Reply With Quote
Ok latest updte. Ive odered a new fan stat switch from Halfrauds. Computer saidit was 90 - 82 switch so im hoping it works at lower range to mine (i know temp ranges are subject to where sender is etc). Is the temp range marked on the sensor anywhere - i dont know how to identify mine! Does M16 thread sound std?
Fan override switch is noe fitted so when i enter slow moving traffic areas i can flick it on for a while or if i do conk out at least i can apply fan to cool off quicker.
Water wetter - ivehad mixed feedback on this so will put it low down the list.
Fan cowling - great idea - sounds well fiddly to do right. Will search Hellfire site to see how the foam idea works.
Bonnet vents - dont seem to make a difference. Hopefully fan override with bonnet vents will.
Exhaust wrap - on my list of to do jobs.
Thanks for ideas.
DarrenW
posted on 6/5/06 at 11:04 PM Reply With Quote
Thanks for ideas.
