darrens
| posted on 7/5/06 at 03:14 PM |
RV8/LT77 Clutch Slave Cyl fittings
Has anyone done similar to this and gone through an SVA OK, This is obviously trying to avoid the extreme prices of rimmers.
Basicaly from clutch cyl to Master
M12 Male to short peice of 3/16 copper, then to female 3/8" (or M10 which ever your fittings) then continue using flexi braided hose back to
Master cylinder
Regards
| posted on 7/5/06 at 03:31 PM |
Pretty sure that SVA regs will not cover clutch so you should be OK . wait for incoming flak?
need4speed
| posted on 7/5/06 at 03:37 PM |
Have a word with wilkingj I'm sure I read that he did something on the same lines as to avoid Rimmers prices.
Dave
froggy
| posted on 7/5/06 at 04:08 PM |
does it work ok? i think the rover uses a 5/16 pipe from master to slave but i doubt the difference would stop it working as the displacement would
be the same
DanP
| posted on 7/5/06 at 04:09 PM |
O/T: hehe trying to avoid the silly cost of the flywheel cover plate too i see
I managed to modify the auto one that came with my engine.
[Edited on 7/5/06 by DanP]
mark chandler
| posted on 7/5/06 at 04:37 PM |
Series III landrovers have an adapator which make this conversion which bolts on to the master cylinder, costs pennies.
But then whenever you buy v8 rover look at the equivilent Landrover item to save money.
Regards Mark
Paul (Notts)
| posted on 7/5/06 at 05:46 PM |
Try getting in touch with..
http://www.paddockspares.com/
they do clutch hoses for v8 gearbox for under £10
darrens
| posted on 7/5/06 at 08:34 PM |
be the same
Not tried it yet (waiting for resovoir to master cyl hose to be delivered, but your right the original was the bigger 5/16 pipe, cover plate I have
but forgot to fit, when I get five.
Will see what happens and give paddockspares a call if needed.
Agriv8
| posted on 7/5/06 at 08:52 PM |
SVA'ed mine with similar braided hoses no problems.
my local indipendant Landrover is a good place for certain v8 bits. ( cheeper than Rimmer Bros - but there website is v.good )
Regards
Agriv8
wilkingj
| posted on 7/5/06 at 10:11 PM |
I used the M12 to 3/16" pipe adaptor from Rally Design. Then took the copper pipe to a bracket on the side of the engine mount.. There I had a
Fiesta Rear brake hose (M10 Male Both Ends) that jumped the gap to the chassis. Another bracket on the chassis (to mount the Male end of the Flexi
pipe) and some copper pipe to the master cylinder.
Its 3/16" all the way through and drives / changes gear OK, as I have been for the MoT. No problems.
Agree about Paddocks, good place for cheap Landy Bits. Rimmers are a tad expensive
Best Regards
Geoff
http://www.v8viento.co.uk
Simon
| posted on 7/5/06 at 10:53 PM |
Mine didn't change much from this.
It could do with tidying but was ok for test.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2004_0226Image0009.JPG
Simon
darrens
| posted on 21/5/06 at 07:35 AM |
finally got correct hose and got it bled, works a treat, lighter than I thought it would be, had TVR few years back and you needed a strong left leg
to operate the clutch in that.
just need wheels, exhaust, and megasquirt finshing and I can then take it for a blast.........
........a few metres down the drive
