Author: Subject: Pinto Cylinder Head Bolts
Tinks
posted on 8/5/06 at 12:46 PM Reply With Quote
Does anyone know why the Haynes manual states " if Torx drive head bolts have been used then these must be replaced"
John
mookaloid
posted on 8/5/06 at 12:52 PM Reply With Quote
It's because they stretch permanently when you torque them down then give them and extra measured 45 deg? turn.
If you reuse them then you will be stretching them a second time and you would be risking uneven tightness or even failure.
HTH
Mark
flak monkey
posted on 8/5/06 at 12:55 PM Reply With Quote
What Mark said
The newer pinto engines with the torx head bolts have to have the bolts replaced everytime you have the head off. They arent that expensive.
The older engines used different bolts that could be reused twice i think. You can still buy the older style bolts if you want to...
Sera
http://www.motosera.com
Tinks
posted on 8/5/06 at 01:00 PM Reply With Quote
Thanks Guy,s but from a Ford dealer they are £3.50 each
mookaloid
posted on 8/5/06 at 01:04 PM Reply With Quote
I buy em of fleabay for about £10 per set - they seem ok
mookaloid
posted on 8/5/06 at 01:06 PM Reply With Quote
Here you go
http://cgi.ebay.co.uk/FORD-PINTO-HEAD-BOLT-SET-TORX-Bolts-VHBS-056_W0QQitemZ8063259918QQcategoryZ27377QQrdZ1QQcmdZViewItem
Tinks
posted on 8/5/06 at 01:12 PM Reply With Quote
THANKS !!!!!!!!!! saves me about £25
James
posted on 8/5/06 at 01:19 PM Reply With Quote
I always get a main dealer quote for bits because then everywhere else I go to for a quote seems so nice and cheap!
You want to find yourself a comprhensive motor factors near you as you'll need loads of bits and will save a fortune over Ford. I have a (now very large) spreadsheet that I fill out with all the different parts and prices I've got quotes for!
All the best,
James
Tinks
posted on 8/5/06 at 01:35 PM Reply With Quote
Just found a Motor Factors in Bradford near where I work £1.20 a set getting better
John
geoff shep
posted on 8/5/06 at 01:36 PM Reply With Quote
Torx seem the best bet for replacement despite the slightly higher cost. You can re-use the older type but you have to re-torque them after so many miles or something which means taking the rocker cover off again.
On a connected note, I want to change my camshaft and have the older head bolts, so I need the spline tool - anyone know the bit size offhand. However, since I'd have to get the tool, and replacement bolts and a torx bit I think I might just lift the engine out. Why can't the cam come out forwards!
posted on 8/5/06 at 01:48 PM Reply With Quote
Because it physically won't go through the holes?
geoff shep
posted on 8/5/06 at 03:00 PM Reply With Quote
Yeah I know it won't, I guess what I meant to say was 'Why oh why can't the bl**dy thing come out forwards'
