Author: Subject: Hydraulic Clutch - Parts Needed!
tigersupercat
posted on 15/5/06 at 06:42 PM Reply With Quote
Evening all..
I have managed to convert my sierra pedal box and type 9 gearbox to hydraulic clutch using a landrover master cylinder and a wilwood pull slave cylinder.
The pushrod on the lanny master cylinder is about an inch too short and I need to join it to a piece of threaded rod.. (at the moment it is locked together using 3 nuts but this is bound to vibrate loose!)
This is where the problems start as I cant seem to find any threaded rod joiners with a 5/16" UNF thread.
So, anyone know where I can get a joiner with a 5/16 UNF internal thread (plenty of metric ones available) or is there anyone out there who could make one up for me for some beer tokens!
http://www.tigersupercat.com
NS Dev
posted on 16/5/06 at 01:07 PM Reply With Quote
Where are you? If you're near leicester drop in and I'll knock one up for you
tigersupercat
posted on 16/5/06 at 02:41 PM Reply With Quote
Thanks for your offer, I live in Dunstable, nowhere near Leicester!
I dont mind sending you some dosh to cover your cost's and postage etc though....
Ta
Kevin
NS Dev
posted on 16/5/06 at 10:54 PM Reply With Quote
How long does it need to be? I'll try and get one knocked up tomorrow night.
tigersupercat
posted on 16/5/06 at 11:39 PM Reply With Quote
about an inch long should do it..
Thanks alot
NS Dev
posted on 16/5/06 at 11:40 PM Reply With Quote
will make it then u2u to get address to post to.
cheers
Nat
