Simon
| posted on 15/5/06 at 06:44 PM |
Thernodynamicists - help!
Quick q re a theory I have.
I'm tubo'ing my R V8 and have a massive(?) lack of space. I'm gonna use a couple of R5 GT intercoolers.
Is there a reason why I can't have my inlet airflow through the intercooler matrix. As revs increase, so will airflow etc etc.
Simon
Dale
| posted on 15/5/06 at 06:50 PM |
I dont know but if it does not restrict your intake I dont see why not. You definately have me thinging about it now as my Intercooler and intake
are rather close together.
- Just had a second thought about that though.
As you are pushing boost the charge cooler is going to be getting hot and that is going to raise your intake temp which is going to be compressed and
get your IC hotter which is going to raise your intake temps ect. Sounds like it could be meltdown time - well maybe not but probably would lead
to detination.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
indykid
| posted on 15/5/06 at 06:52 PM |
my thoughts entirely
tom
cossey
| posted on 15/5/06 at 07:49 PM |
dont do it.
the intake will get hotter and more restrictive both of which are bad, the post charger temps will be higher and the turbo will have to work harder
which will increase back pressure so reducing efficency.
i tried to work it out properly but gave up because its way to complicated to map out on an h-s diagram.
Kissy
| posted on 16/5/06 at 06:09 AM |
Or you might just consider supercharging instead?
| posted on 16/5/06 at 06:33 AM |
No -- for pretty obvious reasons this will entirely defeat the purpose of having an intercooler in the first place.
Dale
| posted on 16/5/06 at 11:57 AM |
I don't know if this helps but I am looking at putting my intercooler behind the engine just above the transmission tray. Using a long hood
scoop that is kind of a close fit around the top of the valve cover to try and stop letting hot air get into it and using that forced air through the
IC and venting out the side(s) so its not effected by the hi pressure area in front of the windscreen/deflector.
In front of the rad is the best place but does not work in my situation.
Dale
Dale
NS Dev
| posted on 16/5/06 at 12:43 PM |
u2u sent
Simon
| posted on 16/5/06 at 07:14 PM |
Cheers for the U2U - think I see what you mean.
Having been in touch with BS iro MS, he suggested to just go for water injection, so I may do that instead.
Simon
Dale
| posted on 16/5/06 at 07:43 PM |
Alki injection is not a whole lot more work. Just have to not let it get too rich. You can also just sray the outside of the ic to cool at a
certain boost level.
Dale
Dale
DIY Si
| posted on 16/5/06 at 11:36 PM |
Most of the point of an intercooler is to reduce the temp increase induced by the turbo, so you really need the 'cooler after the turbo. If
it's before it will cool the air slightly, but only for the turbo to then raise the temp by a silly amount. Thus wasting time, and indeed,
effort.
