Sideways 2 Victory
| posted on 11/4/03 at 08:24 PM |
Dellorto Question
Hi all,
Finally got the engine installed today.
I noticed an engine height/bonnet clearance issue as the highpoint of the engine is a large brass bolt head on top of the front carb, this will just
foul the bonnet by about half its height.
Anyone know what these are and if I could replace with a flush fitting grub screw or similar?
In peteff's archive theres a photo:
http://forum.locostbuilders.co.uk/upload/dellorto2.jpg
(Cheers peteff)
Its the large flat brass bolt head on the right hand carb, far side centre of that unit between the mounting holes.
Dave
www.nurburgring.org
scutter
| posted on 12/4/03 at 05:13 PM |
Dave, was thinking of going down this route as well. If i can't get a grubscrew then maybe a cut down bolt with a slot cut in the end.
A question along the same lines, does anyone use the choke?
If not what do people thinks of fitting a screw to permanently hold down the choke valve, allowing the top to be cut off the carbs.
All the best Dan.
[Edited on 12/4/03 by scutter]
