Author: Subject: Coil failure
irvined
posted on 17/5/06 at 02:40 PM Reply With Quote
Coil failure
What are the symptoms when your coil/points etc are a bit worn out?
Dawned on me that the xflow used points, and I also remember the coil getting really hot, would this explain any misfiring wierdness?
http://irvined.blogspot.com
posted on 17/5/06 at 06:51 PM Reply With Quote
Take your pick --- Weak spark, difficult cold starting, reatarded igntion, missfire and if they are closed up enough over heating coil.
If you have a Ford/Fomoco/Autolite dizzie the points gap is 0.023" to 0.027" -- the points gap on on these dizzuies tends to close up radiply over the first few minutes use so gap the contacts at the wide end and put a tiny smear of grease on the cam. Re-check the gap after the first few miles running.
