mad4x4
| posted on 24/5/06 at 06:19 AM |
Zetec Engines
Need a list of bits that I need
I have a Zetec 1.8 and need to fit it to a type 9 gearbox then fit 40's and get a spark
Car had a 1.6 CVH in it.
What sensors etc to I need
What engine loom do I need
Any bits for the Clutch
What Alternator plate do I use>
Scot's do it better in Kilts.
| posted on 24/5/06 at 07:57 AM |
CVH and Zetec blocks come from the same family tree, a lot of Westie owners have done this coversion. I don't know exactly how the CVH is
mounted i your car but it should be possible retain one of the existing engine mounts. Various diameter clutches were used in the 1600 CVH so I
can't comment on the clutch apart from saying it may be possible to use all or part of the existing setup.
The CVH exhaust manifold can be fitted to the Zetec --- the bolt holes don't line up but that can be got round -- there is info out on the web
about this.
As for spark it would be best to go the whole hog and use Megasquirt for fueling as well. Induction arangments would depend on how much under bonnet
clearance you have and where your master cylinder is fitted but you have a choice of throttle bodies, bike throttle bodies or if you have a bit of
extra room the Rover 220/820 inlet manifold.
Lots of good info on this site http://www.zetec-cat.co.uk/
Danozeman
| posted on 24/5/06 at 09:25 AM |
If your going 1.8 zetec you best bet is to get one from an escort. Itl have the lighter flywheel and the correct water pump and grooved pulley.
If your zetec is from a mondeo you will need a water pump from an escort 1.8 zetec or 92 fiesta 1.8 zetec.
You will need the crank sensor on it and the cam sensor to can be left if to block the hole in the head up but not used.
Megajolt is your best bet for the ignition if your using carbs and alot cheaper than omex, emerald etc.
Clutch from an early 1.8 mondeo and release brg from a capri/transit. Quinton hazel part no for brg is cct133.
Also youl need a pinto spigot brg. The part no is on the link above.
You will find THIS link handy.
And this
[Edited on 24/5/06 by Danozeman]
Dan
