Author: Subject: why why why
jacko
posted on 27/5/06 at 05:39 PM Reply With Quote
why why why
Hi all i went for a ride today and the engine blew some oil out the oil filler breather it has never happend before . Can any body tell me what could cause this please . Jacko
andyharding
posted on 27/5/06 at 05:42 PM Reply With Quote
Easy - blocked crankcase breather.
Hard - valve stem seals / rings / blown head gasket.
I had loads of oil blowing out of the breather when my valve stem seals went.
Andy W
posted on 27/5/06 at 05:43 PM Reply With Quote
Keeping up with a B.E.C.
jacko
posted on 27/5/06 at 05:54 PM Reply With Quote
passed you down the motor way PINTO POWER
MkIndy7
posted on 27/5/06 at 05:57 PM Reply With Quote
Ours did it when we first got the Twin 40's
Have you removed the one way Valve in the crank case breather?
In the Sierra it uses vaccume pressure from the carb to open the valve to let the crank case fumes out.
You've probably already done it but hopefully its that and nothing more serious!
stevec
posted on 27/5/06 at 05:58 PM Reply With Quote
Had the same thing on my Transit once, Piston had gone, Same engine isnt it?
jacko
posted on 27/5/06 at 06:04 PM Reply With Quote
Hi MK INDY i have not removde the valve yet Chris Mason mentioned this today is there a link on hear about this i have tryed a search but cannot find it Graham
MkIndy7
posted on 27/5/06 at 06:21 PM Reply With Quote
I can't remember if its removable or if we had to drill it out, but its in the bung that plugs into the crank case breather.
With the 40's we then ran the pipe to a little breather filter but we probably should have changed to a catch tank really.
jacko
posted on 27/5/06 at 06:28 PM Reply With Quote
does this stop rocker cover pressure ?
Graham
mookaloid
posted on 27/5/06 at 07:38 PM Reply With Quote
Hi Graham
Now you are on bike carbs you need to make changes to your breathing system.
have a read of this
http://members.aol.com/sarandrews/wateroil.htm
cheers
Mark
MkIndy7
posted on 27/5/06 at 09:03 PM Reply With Quote
It did on ours yes, before it was forcing it out of the oil filler hole on the cam.
The increase in pressure in the crank case must presurise the oilways and therefor the cam cover
