Author: Subject: Zetec water pump
iant
posted on 28/5/06 at 11:18 AM Reply With Quote
Zetec water pump
I need to change the water pump on my 2.0Ltr mondeo Zetec, because with the new belt set up it will run the wrong way around. I think I need an Escort water pump but I need someone to confirm this.
If I'm right does anyone know the ford part number or of a good place to get one online?
BKLOCO
posted on 28/5/06 at 11:38 AM Reply With Quote
I got mine from fleabay.
I don't know the part number but if you have a silver top engine you need the pump that has the inlet straight out of the side of the pump not the one that is angled backwards.
big_wasa
posted on 28/5/06 at 12:28 PM Reply With Quote
You will also want the pulley that bolts to it.
givemethebighammer
posted on 28/5/06 at 12:58 PM Reply With Quote
it's an escort 1.8 16v (zetec) pump if I remember correctly and big_wasa says you'll need the ribbed pulley (2.0L mondeo one is flat) as well (from ford)
Something like a "P" reg should get you the pump you need.
[Edited on 28/5/06 by givemethebighammer]
Danozeman
posted on 28/5/06 at 02:30 PM Reply With Quote
I got a water pump from a 1.8 fiesta and the matching pulley. The pump was about 15 quid from Jayar parts and the pulley was 11 quid from ford.
Dan
