peterriley2
| posted on 30/5/06 at 11:10 AM |
lsd- non lsd
i just wanted to know what the difference in the two are once installed in a locost, what difference do they actually make, and would it be worth
trying to convert my non lsd to lsd? help would be much appreciated.
joel
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
phoenix70
| posted on 30/5/06 at 12:00 PM |
It really depends on what you are using the car for. If it's for Track use, then yes an LSD makes a difference, but the downside is it does
make it a bit more of a handful to drive normally (The LSD makes it understeer a little more). If it's a road car, then I wouldn't
bother.
smart51
| posted on 30/5/06 at 12:33 PM |
I have a sierra LSD and have had no problems with understeer.
The theory is that if one of the rear wheels spins then the viscous coupling activates. This limits the slip of the rear axle, giving you drive. The
effect of limiting the slip will promote a bit of understeer, after the rear end slip has started. I haven't noticed a problem.
An LSD with lobro shafts is about 10kg heavier than an open diff. The weight saving may be of more use than the slip limiting.
